Inventor General
Distinguished Contributor
zdhrichard
Message 1 of 20 (765 Views)
Accepted Solution
How to delete suppressed components by iLogic Rule
765 Views, 19 Replies
01-24-2013 06:21 AM
I have an assembly which includes lot of parts (*.ipt) or sub-assembly (*.iam).
I have some ilogic rules to control to suppress or unsuppress them.
Now for the released assembly, I want delete all suppressed components by ilogic rule.
Could anybody help me the ilogic code to get this function?
Rich
Autodesk Inventor Professional 2013 (64 Bit) SP2
Windows 7 Professional Service Pack 1
Intel(R) Xeon(R) CPU E5645
12.0 GB Memory
*Expert Elite*
mrattray
Message 2 of 20 (756 Views)
Re: How to delete suppressed components by iLogic Rule
01-24-2013 07:26 AM in reply to: zdhrichard
Dim oComp As ComponentOccurrence
Dim oComps As ComponentOccurrences
oComps = ThisDoc.Document.ComponentDefinition.Occurrences
For Each oComp In oComps
	If Component.IsActive(oComp.Name) = False Then oComp.Delete
Next
Mike (not Matt) Rattray
Valued Contributor
waynehelley
Message 3 of 20 (752 Views)
01-24-2013 07:44 AM in reply to: mrattray
Hi Mike, by any chance do you know how to do the same but for deleting suppressed features in the part environment?
Wayne Helley
Inventor 2013 Certified Professional
Windows 7 Enterprise, 64-bit
*Expert Elite*
mrattray
Message 4 of 20 (749 Views)
01-24-2013 07:58 AM in reply to: waynehelley
Dim oFeature As PartFeature
Dim oFeatures As PartFeatures
oFeatures = ThisDoc.Document.ComponentDefinition.Features
For Each oFeature In oFeatures
	If Feature.IsActive(oFeature.Name) = False Then oFeature.Delete
Next
zdhrichard
Message 5 of 20 (736 Views)
01-24-2013 10:48 AM in reply to: mrattray
Thanks lot, Mike.
Rich
12.0 GB Memory
zdhrichard
Message 6 of 20 (734 Views)
01-24-2013 10:54 AM in reply to: mrattray
Hello MIke,
For deleting features, do you know how to delete the relative sketches?
I tested the codes, it could delete features, but the sketches are still in the tree.
Rich
12.0 GB Memory
*Expert Elite*
mrattray
Message 7 of 20 (728 Views)
01-24-2013 11:00 AM in reply to: zdhrichard
When I tested it the code deleted the consumed sketches as well as the feature. Can you attach the model?
zdhrichard
Message 8 of 20 (724 Views)
01-24-2013 11:23 AM in reply to: mrattray
Here is a simplified model.
Rich
12.0 GB Memory
*Expert Elite*
mrattray
Message 9 of 20 (720 Views)
01-24-2013 11:31 AM in reply to: zdhrichard
Did you already run your delete features sub on this part? The code doesn't do anything at all for me.
zdhrichard
Message 10 of 20 (715 Views)
01-24-2013 11:43 AM in reply to: mrattray
Yes, I did. This is the result after runing the code.
Rich
12.0 GB Memory
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
