Inventor Forum
How to customize the thickness of edges...
4 REPLIES 4
SORJM
2164 Views, 4 Replies
Is there is any way of customizing the thickness of edges. I want to customize this... I am using Autodesk v2012
4 REPLIES 4
yannick3
in reply to: SORJM
Hi
Maybe if you create 3D sketch  all around your model and change the property of sketch -Close the 3D sketch RMB on sketch node, and select sketch property
after you must change the range in the document setting
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
SORJM
in reply to: yannick3
Thanks for the response the model was created with surface feature. I want to know is there any option for the model edges that are shown in Autodesk Inventor can be modified or not. The defalt colour is black is this can be modified...
yannick3
in reply to: SORJM
Yes
go to application option, dispaly,appearance, check "use application options " and for finish setting and choose the color
 if you want to isolate the style to only this part, check document setting (in application option display tab)and
go to document setting (icon beside application option) and use same behavior that application options
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
SORJM
Thanks a Lot your suggestion worked.
Regards
Nisheeth Srivastava
3D Parametric Solid Model Drawing
