Is there is any way of customizing the thickness of edges. I want to customize this... I am using Autodesk v2012
Solved by yannick3. Go to Solution.
Hi
Maybe if you create 3D sketch all around your model and change the property of sketch -Close the 3D sketch RMB on sketch node, and select sketch property
after you must change the range in the document setting
Thanks for the response the model was created with surface feature. I want to know is there any option for the model edges that are shown in Autodesk Inventor can be modified or not. The defalt colour is black is this can be modified...
Yes
go to application option, dispaly,appearance, check "use application options " and for finish setting and choose the color
if you want to isolate the style to only this part, check document setting (in application option display tab)and
go to document setting (icon beside application option) and use same behavior that application options
