Inventor General
AndrewBeekman9108
Message 1 of 11 (410 Views)
Accepted Solution
How to create sketch geomerty that can be used to define planes, axes and points
410 Views, 10 Replies
11-06-2012 10:58 AM
This is probably a very basic problem that hopefully has a simple solution.  I am using projeted and sketched geometry (2D sketches) in assembly space to create lines/ points that I intend to use to define planes and axes. The problem I have is that nearly all the geometry I create (lines and ponts in 2D sketches) is not "selectable" when I try to create planes or axes.  I  cannot even put a work points "on top of" my sketch points.  Why are my sketches not usable in the assembly space?   Since the components in my model are just two extruded rings I don't ahve any linear edges I can select to make this work/ define planes.
Thanks for the help.
*Expert Elite*
Cadmanto
Message 2 of 11 (405 Views)
Re: How to create sketch geomerty that can be used to define planes, axes and po
11-06-2012 11:12 AM in reply to: AndrewBeekman9108
Just wondering.
When you try to use these sketches in your assembly are you working in "Model View"
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
AndrewBeekman9108
Message 3 of 11 (394 Views)
11-06-2012 11:47 AM in reply to: Cadmanto
I am in the asembly view as opposed to part or sketch view.   I am in the view that presents the "place" or "create" options for parts in place and the option to create work features in the 3d tab.  The geometry I wish to "use" is created on sketch planes.
Distinguished Contributor
JimSteinmeyer
Message 4 of 11 (380 Views)
11-06-2012 12:48 PM in reply to: AndrewBeekman9108
Andrew,
While you are in the sketch, right click in the drawing to bring up your menu options. In the lower right of the wheel there is an option called "Project Geometry" select this and then select what ever you want to use for referance as it will be available. remem that this created a referance to the part or assembly you used so depending on how you prefer to do things you may want to break the referances after the new model is fully defined.
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
*Pro
sbixler
Message 5 of 11 (347 Views)
11-07-2012 03:53 AM in reply to: JimSteinmeyer
If I'm understanding the OP correctly, he is creating a sketch at the assembly level (an assembly sketch), but no elements of this sketch are selectable to define work features.
This issue just came up yesterday for one of my colleagues, and we'd like an answer, too.  How can one define an assembly work feature using assembly sketch geometry?  If not possible, why not?
AndrewBeekman9108
Message 6 of 11 (334 Views)
11-07-2012 04:43 AM in reply to: sbixler
sbixler- you are correct, we have the same problem/ question.
With regard to the project geometry response, the project geometry command is not available in the "assembly" space.  I was able find somewhat of a work around in that if I start the "create a part in place" command and generate the sketch planes and points that I need to create that 1 part I am able to reference them for creatation of axes and planes.  The axes and planes created are not selectable outside of the one part though so they need to re-created if needed in for generation of a 2nd part.
*Expert Elite*
karthur1
Message 7 of 11 (328 Views)
11-07-2012 05:08 AM in reply to: AndrewBeekman9108
Andrew,
You should be able to select your sketch geometry in the assembly to create planes or work axis. Dont think you will be able to select the circle, but you can select the center point.  If you need a plane tangent to the circle, in you sketch draw a line from the center of the circle, to the tangency point.  You can then select this point when you are in the iam.
 Is your sketch visible in the iam?  Watch this video
If this doesnt help, post a picture of what you are doing.
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1
Vault Basic 2013
*Pro
sbixler
Message 8 of 11 (319 Views)
11-07-2012 05:51 AM in reply to: karthur1
He's creating the sketch in the assembly, not in a component part.  Creating it in the component part is a workaround in some cases, but may not be possible in others.
*Expert Elite*
karthur1
Message 9 of 11 (308 Views)
11-07-2012 06:26 AM in reply to: sbixler
Oh...creating the sketches in the iam environment....wont be able to create work planes/ Axis from those....
Sorry.
AndrewBeekman9108
Message 10 of 11 (296 Views)
11-07-2012 08:10 AM in reply to: karthur1
I'm curious what purpose creating sketes in the iam enviroment would serve if not to create reference geometry to create/ position other components?  I may be missing something fundamental here but that seems like it would be the main reason this command is available in iam?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
