We use work points in the IPT's to create center punch marks for weld studs. But we do it like this........ After the IPT is created, then create your IDW. Upon placing your view, click over to options and show Work Features. This will put "SCRIBE" lines (work point crosses) on there. Be carefull though. If the part was done using sheetmetal mode, double check the location of those scribe lines. I have had numerous cases where scribe work points are on one flange and scribe work points are on another flange. When IV7sp1 goes to flatten it in the IDW, the locations of these points are not in the location i put them. I have even sent the IPT & IDW files to my VAR, who forwarded it to Autodesk. Guess what, no response back from either of them, and that was back in release 6.0.
Thank You
Steve Harrity
Senior Mechanical Designer
Universal Dynamics, Inc.
A Company of MANN+HUMMEL ProTec
13600 Dabney Road
Woodbridge, VA 22191
703-490-6122 office
703-491-6898 fax
http://www.unadyn.com
