Inventor General
Distinguished Contributor
Message 1 of 3 (134 Views)
Accepted Solution
How to create a new ipt related to another existant ipt
134 Views, 2 Replies
09-22-2012 10:41 PM
Hi everyone,
If a could get an answer to this one, it would be great!
Here is the simplifyed question :
I have a part called rectangle.ipt (simply a rectangle in it).
I have to creat another part, called rectangle_holes.ipt. This one, is the same as rectangle.ipt, same dimensions, but has holes in the rectangle.
Is there a way that theses 2 parts could be related, so that if the dimensions of rectangle.ipt changes, rectangle_holes.ipt  automaticaly changes?
Thanks!
Sophie
Member
Message 2 of 3 (125 Views)
Re: How to create a new ipt related to another existant ipt
09-23-2012 12:51 AM in reply to: SophieSmith
You could make the first rectangle and save it.
Then open a new ipt. file. Go to manage and derive the rectangle, then add what ever you want, and save the part.
What ever you do to the first rectangle will now be updated into your second file.
 Let me know, if you can use this solution :smileyhappy:
Message 3 of 3 (100 Views)
09-23-2012 10:42 AM in reply to: bundsgaard.mick
Your answer is perfect!
Thanks So much! :-)
Sophie
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
