Inventor General
bravaiser
Message 1 of 3 (158 Views)
How to create a Workplane from a face using SelectSet[]
158 Views, 2 Replies
11-08-2012 02:13 PM
I am making a C# Add-in, I need to create a plane from a selected face, I am using the follwing code, but I am getting stuck. Can you Help me?
if (((mApp.ActiveDocument != null)))
if ((mApp.ActiveDocument.DocumentType == DocumentTypeEnum.kPartDocumentObject))
PartComponentDefinition oPartCom = mApp.ActiveDocument as PartComponentDefinition;
PartDocument oDoc = mApp.ActiveDocument as PartDocument;
if ((oDoc.SelectSet[1]) is Face)
System.Windows.Forms.MessageBox.Show("You just selected a surface", "Surface Evaluator");
WorkPlane oPlane = oDoc.SelectSet[1] as WorkPlane; //HERE I SELECT THE WORKPLANE FROM THE FACE
//HERE I USE IT TO CREATE MY REAL WORKPLANE TO USE THE SKETCH BUT THERE IS A PROBLEM
WorkPlane oWorkPlane = oDoc.ComponentDefinition.WorkPlanes.AddByPlaneAndOffset(oPlane, 1.0);
//THIS PART SHOULD WORK AFTERWARDS
PlanarSketch oSketch = oDoc.ComponentDefinition.Sketches.Add(oWorkPlane, false);
TransientGeometry oTG = mApp.TransientGeometry;
ObjectCollection oFitPoints = mApp.TransientObjects.CreateObjectCollection();
PartComponentDefinition oCompDef = default(PartComponentDefinition);
oCompDef = oDoc.ComponentDefinition;
Camera oCamera = mApp.ActiveView.Camera;
THANK YOU GUYS!!!
Mark_Wigan
Message 2 of 3 (122 Views)
Re: How to create a Workplane from a face using SelectSet[]
11-12-2012 05:23 AM in reply to: bravaiser
You could get better reponse if you post this in the inventor customisation section.
You mention there is a problem... when you repost, also mention what the problem is that you are encountering.
best regards,
- Mark
PDSU 2014 Windows 7, 64bit. (please consider Kudos or Tag as Solved if your issue is sorted)
bravaiser
Message 3 of 3 (118 Views)
11-12-2012 05:30 AM in reply to: bravaiser
The problemis that the plane oPlane is pass as null to when I used the selection (in this case a face) oDoc.SelectSet[1] as WorkPlane.
Thanks in advance
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
