Inventor Forum
How to create LOD with hole feature suppress at assembly level?
1 REPLY 1
shah_falgun
445 Views, 1 Reply
In order to reflect production process, I have to create holes on the bent pipe at assembly level after 2 bent pipes are welded to the straight pipe. Now when I suppress holes, it does not suppress only at LOD or view rep but throught the whole assembly.
Is it possible to suppress features such as hole using LOD or view rep, which are made at the assembly level? or I have to use another method? See below in highlighted.
1 REPLY 1
shah_falgun
in reply to: shah_falgun
I search more and now find the way to do this, using substitue assembly it worked, where I created new level of detail using substitue assy, which in turn creates shrinkwrap part file, whithout hole features.
