Inventor General
Member
Message 1 of 7 (928 Views)
How to convert 3d dwg files to solid bodies
928 Views, 6 Replies
06-25-2012 09:06 PM
Please anyone tell me how to convert 3d dwg files to solidbodies
Valued Mentor
Rich.O.3d
Message 2 of 7 (924 Views)
Re: How to convert 3d dwg files to solid bodies
06-25-2012 09:58 PM in reply to: p.raviteja1992
open the dwg in inventor
when you have the dwg selected in the open dialogue, hit the options button and make sure you set to import
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Member
Message 3 of 7 (921 Views)
06-25-2012 11:36 PM in reply to: Rich.O.3d
Thank you
but i think there is some problem with my inventor.
I can get the preview but i can't get the body
Please check if there some problem with my dwg file
If possible upload the part file
wh
Message 4 of 7 (909 Views)
06-26-2012 03:35 AM in reply to: p.raviteja1992
There are no really good results, the source is only a mesh.
I can't upload the file because of it's size (about 4 MB). Try again for yourself Open -> DWG import. Import is lasting several minutes
Walter
Message 5 of 7 (897 Views)
06-26-2012 04:34 AM in reply to: p.raviteja1992
Your problem title is incorrect - as indicated by Walter there are no solids in the file.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 6 of 7 (895 Views)
06-26-2012 04:38 AM in reply to: JDMather
You might be able to open a layer at a time and separate into different parts and stitch to solids - but I think I would start over and do the model correctly (as solids rather than meshes).
Valued Mentor
Rich.O.3d
Message 7 of 7 (873 Views)
06-26-2012 04:00 PM in reply to: JDMather
hmmm polyface mesh!
would these be prosteel objects?
if so you need to use export to an acis file ( _PSCREATEACIS or something like that, its been a while)
then you can bring into inventor
CAD Management 101:
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
