Inventor General
a.prokop
Message 1 of 10 (464 Views)
How to change the language of tooltips on the ribbon?
464 Views, 9 Replies
10-22-2012 11:12 AM
Welcome.
I have Polish version of Autodesk Inventor 2013 Profesional.
Tooltips display ribbons to me in English.
How do I set to display them in the Polish language?
Thank you in advance for your help.
blair
Message 2 of 10 (451 Views)
Re: How to change the language of tooltips on the ribbon?
10-22-2012 04:37 PM in reply to: a.prokop
Did you download and install the language package?
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18550979&linkID=9242019
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
a.prokop
Message 3 of 10 (440 Views)
10-23-2012 01:43 AM in reply to: a.prokop
I tried.
I can not install the Polish version because that is already installed.
So he sees the system.
blair
Message 4 of 10 (418 Views)
10-23-2012 08:34 AM in reply to: a.prokop
It could be a bug, are you on the current SP 1.1?
Win7-64
a.prokop
Message 5 of 10 (414 Views)
10-23-2012 09:29 AM in reply to: a.prokop
SP 1.1 is installed.
I did a test. I have uninstalled all the patches and service packs.
The error is still there.
Once installed SP 1.1.
blair
Message 6 of 10 (410 Views)
10-23-2012 09:39 AM in reply to: a.prokop
I hope that someone from Autodesk looks at this thread, it must be a bug. Check with your reseller or if you are on support, log a support call.
Win7-64
a.prokop
Message 7 of 10 (312 Views)
01-05-2013 01:10 AM in reply to: blair
Recently swapped the files in the Templates folder to the new and the problem disappeared. Tooltips have the correct language.Unfortunately, only for a moment. After a few days I have tooltips again in another language. It will give it to someone can answer why this is happening.
Valued Mentor
Mason-Paul
Message 8 of 10 (303 Views)
01-05-2013 04:07 AM in reply to: a.prokop
This could also be connected to your keyboard language settings with in Windows see the attached.
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
a.prokop
Message 9 of 10 (256 Views)
01-07-2013 12:01 AM in reply to: Mason-Paul
Unfortunately, it's not. Language settings are fine. The error must be somewhere else.
a.prokop
Message 10 of 10 (214 Views)
01-24-2013 07:08 AM in reply to: a.prokop
Where are the files Tooltips?
Maybe something manually swapping files help?
I found only the files to Fusion.
They are in the directory:
C:\Program Files\Autodesk\Inventor Fusion 2013\pl-PL\Configuration\ToolTips
However, I can not find the files to Invetor.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
