Inventor Forum
How to change the language of tooltips on the ribbon?
9 REPLIES 9
Message 1 of 10
1674 Views, 9 Replies
Welcome.
I have Polish version of Autodesk Inventor 2013 Profesional.
Tooltips display ribbons to me in English.
How do I set to display them in the Polish language?
Thank you in advance for your help.
9 REPLIES 9
Message 2 of 10
blair
Did you download and install the language package?
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18550979&linkID=9242019
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 10
I tried.
I can not install the Polish version because that is already installed.
So he sees the system.
Message 4 of 10
blair
It could be a bug, are you on the current SP 1.1?
Delta Tau Chi ΔΤΧ
Message 5 of 10
SP 1.1 is installed.
I did a test. I have uninstalled all the patches and service packs.
The error is still there.
Once installed SP 1.1.
Message 6 of 10
blair
I hope that someone from Autodesk looks at this thread, it must be a bug. Check with your reseller or if you are on support, log a support call.
Delta Tau Chi ΔΤΧ
Message 7 of 10
in reply to: blair
Recently swapped the files in the Templates folder to the new and the problem disappeared. Tooltips have the correct language.Unfortunately, only for a moment. After a few days I have tooltips again in another language. It will give it to someone can answer why this is happening.
Message 8 of 10
Paul-Mason
This could also be connected to your keyboard language settings with in Windows see the attached.
Inventor 2025 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 9 of 10
in reply to: Paul-Mason
Unfortunately, it's not. Language settings are fine. The error must be somewhere else.
Message 10 of 10
Where are the files Tooltips?
Maybe something manually swapping files help?
I found only the files to Fusion.
They are in the directory:
C:\Program Files\Autodesk\Inventor Fusion 2013\pl-PL\Configuration\ToolTips
However, I can not find the files to Invetor.
