Hello all,
I have an older drawing with an outdated sheet format. I'm wanting to update to a new custom sheet format without having to redimension and recreate views. Is it possible to just update the sheet format? Thanks in advance for your help.
Using Inventor Pro 2014
Drawing Resource Transfer Wizard.
It runs outside of IV and takes resources from a source idw and transfers them to a target idw.
If the resources have the same name, it will overwrite the old ones.
If the resources have different names, you get to edit each drawing seperatly, I think.
I also use an add-in called: Auto Update Drawing Resources
http://www.mcadforums.com/forums/viewtopic.php?t=8018
to update my idws each time I open them.
Steve Walton
