Inventor General
Active Member
Message 1 of 4 (241 Views)
How to add a bump map to a texture
241 Views, 3 Replies
09-13-2009 03:50 AM
Hi there i am workin on a model in inventor and i want it too look as good as possible, so one of the things that i need is to bump map a texture. Please help me.
I have a custom texture and a bump map file as well but where do i put it?
Mark_Flayler
Message 2 of 4 (241 Views)
Re: How to add a bump map to a texture
09-13-2009 07:26 AM in reply to: dtrford
You do this in Inventor Studio. The bump map will not appear until you render it. Adjust Surface Styles as necessary to get to your goal.
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
Message 3 of 4 (241 Views)
09-13-2009 12:53 PM in reply to: dtrford
>where do i put it?
You didn't mention what version of Inventor you are using.
You will also need to become familiar with the Styles Editor.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
scottmoyse
Message 4 of 4 (241 Views)
09-16-2009 08:16 PM in reply to: dtrford
u don't actually need a bump map if you don't want one. Well i know thats for sure in 2010. In studio under the texture styles you can check a box to use the color bitmap as the bump map as well.
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
