I'm guessing this is possibly an easy question to answer. Most likely with a straight "No, you can't", but I'll ask anyway!
I have several parts which I wish to modify, but, those modifications are only being done to get some prototypes made. I do not want the changed (non-approved part) to be used in current issue drawings, assemblies etc. until I have proven the modifications and am happy with them.
I can do this by doing a save as on the part and could just replace the previous design, but then I lose the history of changes/revisions shown in Vault which is critical to me and part of using vault in the first place.
Is there any around this or am I missing something bleedin' obvious?
Thanks for any help
Bob
I think, if it were me, I'd leave the approved part and drawings alone. Do a "save as" or copy design if you're talking about an assembly. I would give the new part file a different name and/or part number, something to differentiate it as a prototype. Create a new drawing for it, or do a save as on your approved drawing and "replace model geometry" on the prototype version.... to show your modified model. That way there is no chance (or little chance,,... can't rule out human error) of mixing them up.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Bob,
Are you using basic Vault or one of the higher versions such as Vault WorkGroups?
If basic Vault then I'm sure you understand that you only have version control and not Revision control???
If you have say, WorkGroups, the file should be in a "prototype" state until released for production thus solving your situation a bit.
But if you have basic Vault, I think the easiest thing you can do is to suppress the features you have for the prototype.
Not knowing if you're going to build the prototype by drawing or by model, this process might be the quickest and easiest way to do what you need for the time being. There are other ways, but they might be a bit cumbersome to explian here real quick. Sorry, it's been a while since I've had to attempt this process so I'm sure others may have other ideas.
I only have Vault basic currently. I quite like the idea of just suppressing the new features until I'm ready to release. Not perfect but I can see that it's my best option without upgrading Vault.
Many thanks
