Inventor General
Member
design
Message 1 of 4 (240 Views)
How to Modify a part without updating linked parts/assemblies/drawings?
240 Views, 3 Replies
11-12-2012 10:49 AM
I'm guessing this is possibly an easy question to answer. Most likely with a straight "No, you can't", but I'll ask anyway!
I have several parts which I wish to modify, but, those modifications are only being done to get some prototypes made. I do not want the changed (non-approved part) to be used in current issue drawings, assemblies etc. until I have proven the modifications and am happy with them.
I can do this by doing a save as on the part and could just replace the previous design, but then I lose the history of changes/revisions shown in Vault which is critical to me and part of using vault in the first place.
Is there any around this or am I missing something bleedin' obvious?
Thanks for any help
Bob
cbenner
Message 2 of 4 (237 Views)
Re: How to Modify a part without updating linked parts/assemblies/drawings?
11-12-2012 11:02 AM in reply to: design
I think, if it were me, I'd leave the approved part and drawings alone.  Do a "save as" or copy design if you're talking about an assembly.  I would give the new part file a different name and/or part number, something to differentiate it as a prototype.  Create a new drawing for it, or do a save as on your approved drawing and "replace model geometry" on the prototype version.... to show your modified model.  That way there is no chance (or little chance,,... can't rule out human error) of mixing them up.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
CelticDesignServices
Message 3 of 4 (235 Views)
11-12-2012 11:13 AM in reply to: design
Bob,
Are you using basic Vault or one of the higher versions such as Vault WorkGroups?
If basic Vault then I'm sure you understand that you only have version control and not Revision control???
If you have say, WorkGroups, the file should be in a "prototype" state until released for production thus solving your situation a bit.
But if you have basic Vault, I think the easiest thing you can do is to suppress the features you have for the prototype.
Not knowing if you're going to build the prototype by drawing or by model, this process might be the quickest and easiest way to do what you need for the time being. There are other ways, but they might be a bit cumbersome to explian here real quick. Sorry, it's been a while since I've had to attempt this process so I'm sure others may have other ideas.
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
Member
design
Message 4 of 4 (184 Views)
11-15-2012 01:05 AM in reply to: design
I only have Vault basic currently. I quite like the idea of just suppressing the new features until I'm ready to release. Not perfect but I can see that it's my best option without upgrading Vault.
Many thanks
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
