Inventor General
Active Contributor
ramkrish
Message 1 of 7 (372 Views)
How to Merge cells in Hole Table
372 Views, 6 Replies
11-08-2012 06:38 PM
hi,
i created hole table but i unable to merge the cells. but i need my output will beas per the input.please help me if you have any idea and make sure it is possible to give ineventor 2011 & 2012.
please find the attached .JPEG file.
thank you,
regards,
ram
*Pro
sbixler
Message 2 of 7 (348 Views)
Re: How to Merge cells in Hole Table
11-09-2012 05:02 AM in reply to: ramkrish
Have you tried the various options in the Edit Hole Table dialog?
Combine Notes will merge the Descriptions for identical holes.  Play around with the other options and see what works for you.
Cadmanto
Message 3 of 7 (344 Views)
11-09-2012 05:07 AM in reply to: ramkrish
Ram,
Another option is you can create the table in Excel and import it into your drawing.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Active Contributor
ramkrish
Message 4 of 7 (288 Views)
12-02-2012 06:19 PM in reply to: sbixler
sam,
i tried but i can not merge the cells.
thank you,
ram
Active Contributor
ramkrish
Message 5 of 7 (287 Views)
12-02-2012 06:22 PM in reply to: Cadmanto
Scott,
export the table in excell is possible. but, in future itis not possible to automatic update. and font size & style also vary.
thank you,
ram
Cadmanto
Message 6 of 7 (283 Views)
12-02-2012 06:33 PM in reply to: ramkrish
When I have imported Excel spread sheets into Inventor drawings when I needed to edit them, they always opened in Excel.  So I am not exactly sure what you are talking about.
Best Regards,
Scott McFadden
*Pro
sbixler
Message 7 of 7 (267 Views)
12-03-2012 03:45 AM in reply to: ramkrish
There must be something unique about your model or styles.  I have used hole tables quite a bit in the last few months, and have no trouble combining hole notes.
Can you post a drawing and model that exhibit this problem?  Perhaps someone here can identify the solution.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
