Inventor General
Active Contributor
Message 1 of 5 (184 Views)
How to Coil a Coil
184 Views, 4 Replies
01-14-2013 04:09 AM
I have a question, can we coil a coil in nventor?
If I have a coil or spring, the I want to coil that coil/spring around another axies, can I??
I use Inv.2012
Thank you in advance
*Pro
sbixler
Message 2 of 5 (167 Views)
Re: How to Coil a Coil
01-14-2013 05:09 AM in reply to: sohmoh
Search this forum.  There have been a number of threads over the last several years dealing with this problem.  I'd try using the Bend tool, I think.  I'm not sure whether you can bend more than 360°, though.  But be aware that this is going to be a resource hog-- helices are really math-intensive.  If you don't need a functional model, you might consider using a textured appearance instead, kind of like the cosmetic threads that Inventor uses on screws.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Active Contributor
Message 3 of 5 (161 Views)
01-14-2013 05:24 AM in reply to: sbixler
Well, Thank you for your quick response
But I tried the Bend comand, it could not help me.
Thank you again for your time sir.
*Expert Elite*
Message 4 of 5 (147 Views)
01-14-2013 06:26 AM in reply to: sohmoh
A better way is with an Excel formula of points to generate a sweep curve.
In Inventor 2013 you can enter the formula directly (unfortunately I don't know it by heart - a search should return the forumla to use).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Contributor
Message 5 of 5 (139 Views)
01-14-2013 06:39 AM in reply to: JDMather
Thank you for your replay :smileyhappy:
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
