Inventor Forum
How to Change the UCS coordinate in inventor 2014
3 REPLIES 3
5399 Views, 3 Replies
We are trying to change the UCS coordinate in assembly. But we cant change it.
Please let us know the solution.
Tushar
3 REPLIES 3
JDMather
Can you unground the grounded component and re-mate to the origin workplanes?
Or do you simply want to change the Top of Front view designation (set to desired orientation and right click on the view cube to reset).
Cadmanto
Tushar,
Take a look at this thread and see if it helps you.
http://forums.autodesk.com/t5/Inventor-General/change-part-coordinate-system/td-p/2966208
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
stefaanboel
in reply to: JDMather
You can't do a redefine?
If this is the solution, push the solution button Smiley Wink (and maybe some kudos)
