Inventor General
Valued Mentor
stevec781
Message 1 of 2 (1,288 Views)
How ot make a Parallel Assembly Constraint
1288 Views, 1 Replies
11-20-2009 02:07 AM
Hi all
I want to constrain 2 parts so that a face of part A is always parallel to a face of part B. The faces are not aligned with any coordinate system planes. I need to be able to drag the parts around for conceptual design so using a constraint with an offset is too slow for making changes.
Is there a way to do this?
Steve
*Sam M
Message 2 of 2 (1,288 Views)
Re: How ot make a Parallel Assembly Constraint
11-20-2009 03:21 AM in reply to: stevec781
instead of using a mate/flush which, as you've said, will need an offset
value, can't an angluar constaint keep them parallel? click both faces and
use 0 deg for flush or 180 for mate - if you need the part to keep its
orientation while being dragged about then use a similar angular constraint
between the origin planes.
hope that helps, Sam
wrote in message news:6292536@discussion.autodesk.com...
Hi all
Steve
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
