Solved by Martin_Goodland. Go to Solution.
CDM,
I'm in the same situation today, but I've tried the suggested solution and it does not work (unless I'm missing something myself).
Here's my attempts and results:
I have a staircase (actually I'm attempting to make a iAssembly so as to be able to create multiple stairscases) that's at a 45 degree. The OSHA standards state the Rise/Run for the Tread Plates to be 8.75" x 8.75" respectively. Note, other angles have differing Rise/Run amounts (@40 degrees, Rise/Run is: 8.0" x 9.5").
So I have the 45 degree stringers set up and the first Tread in place, I select Pattern and select the top edge of the Stringer thus putting the pattern in line with the 45 degree angle. At this point is the issue....what value do you put in for the spacing?
It can't be the Rise, nor can it be the Run....the stairs will not pattern correctly spaced according to the OSHA amounts.
And in my case this is more of a factor on different angled stringers.
If anyone can guide me on how to set up this iAssembly Staircase I'd be extremely greatful.
Hi
This will use the rise and run to work out the hypotenuse length for the pattern.
sqrt(rise^2+going^2)
Edit : Regarding making it work for the various angles. You need to have a few linked parameters set up.
floor_to_floor
number_of_risers
going
riser - this should be floor_to_floor / number_of_risers
stair_angle - this should be atan(riser/going)
You can then key in the floor height required and the number of risers and Inventor will work out the rest. This can then be used to set all the handrail geometry etc. And there will be no constrain issues due to rounding that can be caused if you don't let inventor calculate the exact riser and angle.
Regards
Martin
