I have 2 different diameter cylinders and I would like to create a plane that is tangent to both.
Probably more than one right way... but what I did was to create a sketch on the face of one of the cylinders, project geometry both cylinder OD's. Then sketch a construction line tangent to both cylinders. Finish Sketch. Now create a plane by selecting the sketched construction line. As below:
Like I said, there may be a better way to do this, but this seemed to work and was fairly easy.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
@mlandon wrote:
Sam, Sorry about that, it is in an assembly (.iam) Mike
Attach your assembly here.
Here you go.
In an assembly, just create the work plane from any other plane or geometry you have available, delete any constraints that were automatically created, and then set new constraints to make it tangent to your cylinders.
Rusty
