Inventor Forum
How do you constraint a chain belt concept to a Rounded rectangle
3 REPLIES 3
esjoseph
275 Views, 3 Replies
For a Current Students project, I need to know how to constaint a flatsided chain belt to a rounded rectangle consisting of 2-half circles and 2- parrellel lines. what constraints do i need to use. NOTE: We can't seem to be able to use a mate or flush and a tangent constraint. we need something other than that. we also tried to open a seperate .iam of the belt in a current construction of the project and it does not work either. Edited by: esjoseph on Dec 12, 2008 3:55 PM
3 REPLIES 3
mcgyvr
in reply to: esjoseph
attach the belt and rectangular mating part (zip them into 1 folder)
I'm afraid you will have to post the assembly and all parts,
zipped, along with the version of Inventor you are using in order to get help on
this one.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
JDMather
I suspect the solution will to be a curve driven pattern of a workpoint and then a component pattern, but without the data set this is all a guess. Zip and attach what you have so far as suggested by others.
