Inventor General
*Berry, Patrick
Message 1 of 5 (41 Views)
How do you change the default .stl output resolution?
41 Views, 4 Replies
02-20-2003 09:07 AM
A former employee here once discovered that you can edit the registry to
improve the output resolution of .stl files higher than the default by
making a registry change. Unfortunately I can't remember how he did it.
Anyone know?
Pat
*Berry, Patrick
Message 2 of 5 (41 Views)
Re: How do you change the default .stl output resolution?
02-20-2003 09:10 AM in reply to: *Berry, Patrick
Here's a reply to myself. Just after I posted this I checked my old email
and it turns out he sent me a message describing the registry change. Here
it is:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion5.2\System\Prefe
rences\STL Output
That was for 5.3, I don't know if it still works for 6.
Pat
*Dotson, Sean
Message 3 of 5 (41 Views)
Re:
02-20-2003 07:55 PM in reply to: *Berry, Patrick
Is this something you have to change often? I didn't add that to iTweak as
I didn't think many people would need it. If you do I can add it to the
next version.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Patrick Berry" wrote in message
news:04C475E9D755780DDD20741ABD818804@in.WebX.maYIadrTaRb...
Here
> it is:
> rences\STL Output
> Pat
*Berry, Patrick
Message 4 of 5 (41 Views)
Re:
02-20-2003 11:26 PM in reply to: *Berry, Patrick
Not terribly often but that would be useful. The case I have is that I am
having some die-cast prototype parts quoted using the investment castings
from SLA masters. This process uses an 85 percent hollow SLA with a thin,
solid skin so any sanding or finishing to the master runs the risk of
opening up pores. As a result the gradation of the master shows up in the
cast part and has to be buffed out there. This can be minimized using a
much higher resolution file so in this instance it's nice to be able to
tweak.
Thanks Sean,
Pat
*Dotson, Sean
Message 5 of 5 (41 Views)
Re:
02-21-2003 08:20 AM in reply to: *Berry, Patrick
I'll add it ot the next release...
Sean Dotson, PE
news:06884E941059F189E7DD414968585ADA@in.WebX.maYIadrTaRb...
> tweak.
> Thanks Sean,
> Pat
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
