Inventor Forum
How do you change the default .stl output resolution?
4 REPLIES 4
580 Views, 4 Replies
A former employee here once discovered that you can edit the registry to
improve the output resolution of .stl files higher than the default by
making a registry change. Unfortunately I can't remember how he did it.
Anyone know?
Pat
4 REPLIES 4
Here's a reply to myself. Just after I posted this I checked my old email
and it turns out he sent me a message describing the registry change. Here
it is:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion5.2\System\Prefe
rences\STL Output
That was for 5.3, I don't know if it still works for 6.
Pat
Is this something you have to change often? I didn't add that to iTweak as
I didn't think many people would need it. If you do I can add it to the
next version.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Patrick Berry" wrote in message
news:04C475E9D755780DDD20741ABD818804@in.WebX.maYIadrTaRb...
Here
> it is:
> rences\STL Output
> Pat
Not terribly often but that would be useful. The case I have is that I am
having some die-cast prototype parts quoted using the investment castings
from SLA masters. This process uses an 85 percent hollow SLA with a thin,
solid skin so any sanding or finishing to the master runs the risk of
opening up pores. As a result the gradation of the master shows up in the
cast part and has to be buffed out there. This can be minimized using a
much higher resolution file so in this instance it's nice to be able to
tweak.
Thanks Sean,
Pat
I'll add it ot the next release...
Sean Dotson, PE
news:06884E941059F189E7DD414968585ADA@in.WebX.maYIadrTaRb...
> tweak.
> Thanks Sean,
> Pat
