I'll add it ot the next release...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Patrick Berry" wrote in message
news:06884E941059F189E7DD414968585ADA@in.WebX.maYIadrTaRb...
> Not terribly often but that would be useful. The case I have is that I am
> having some die-cast prototype parts quoted using the investment castings
> from SLA masters. This process uses an 85 percent hollow SLA with a thin,
> solid skin so any sanding or finishing to the master runs the risk of
> opening up pores. As a result the gradation of the master shows up in the
> cast part and has to be buffed out there. This can be minimized using a
> much higher resolution file so in this instance it's nice to be able to
> tweak.
> Thanks Sean,
> Pat
