Inventor Forum
How do I tell What Layer a Line is On.
3 REPLIES 3
mcrump28210
1585 Views, 3 Replies
When I edit a title block I would like to know which layer a particular line is on.  If I right click to activare the "Properties" dialog box.  All it tells ne is that the line is "By Layer".  How can I tell which layer an entity is on?
Thanks!
Michael Crump
Michael Crump
AutoCAD 2013
Inventor 2013
Windows Pro 7 x64
Asus Sabertooth X58
Intel Core i7 960 @ 3.2 GHz
24 GB ram
3 REPLIES 3
Hi mcrump28210,
Select the line(s) and then switch to the Annotate tab, and look for the Format panel. You'll see the layer drop down box listing the current layer. You can use the drop down to change the layer if needed.
I hope this helps.
Curtis
Thanks Curtis!  BTW, I have all of your books and they have been of tremendous help to me.  Thanks Again!!
Michael Crump
AutoCAD 2013
Inventor 2013
Windows Pro 7 x64
Asus Sabertooth X58
24 GB ram
mcrump28210
in reply to: mcrump28210
Curtis,
Is there a way to create a titleblock in Autocad and use it as the basis for an inventor titleblock without creating extra layers.  BTW, as a SC native, born and bred, GO GAMECOCKS!
Mike
Michael Crump
AutoCAD 2013
Inventor 2013
Windows Pro 7 x64
Asus Sabertooth X58
24 GB ram
