Inventor General
Active Contributor
Message 1 of 13 (380 Views)
Accepted Solution
How do I search for text in a file
380 Views, 12 Replies
07-25-2013 08:34 AM
I am brand new to Inventor and I am being given the seemingly simple task of finding the tooling files that needs to be checked for correction on account of parts manufactured out of tolerance. The plotted drawings I'm given has text on in that can help me find the files, but the drawings are huge. Is there a way to find text like I've been doing when given the similar task in Autocad? I see no edit menu in Inventor.
*Expert Elite*
cbenner
Message 2 of 13 (378 Views)
Re: How do I search for text in a file
07-25-2013 08:40 AM in reply to: immunoman
Welcome to the forums....
Um, what exactly are you searching for?  A file, or text within a file?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Active Contributor
Message 3 of 13 (371 Views)
07-25-2013 10:05 AM in reply to: cbenner
That would be text in a file. Even better if there's a way to do through multiple files. Thanks for asking :smileylol:
*Expert Elite*
Cadmanto
Message 4 of 13 (364 Views)
07-25-2013 10:58 AM in reply to: immunoman
Welcome to the forum.
Do you have vault?
Any chance any of this text embedded in properties?
I ask because advanced searches can be done within vault.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
*Expert Elite*
cbenner
Message 5 of 13 (362 Views)
07-25-2013 11:02 AM in reply to: Cadmanto
I'm not seeing any kind of text searching tools in Inventor... what's up with that?  Am I missing it?  This would seem to be basic functionality, some sort of "find and replace" feature.  We do put text notes on drawings after all.
ChrisB
*Expert Elite*
Cadmanto
Message 6 of 13 (344 Views)
07-25-2013 11:49 AM in reply to: cbenner
As far as I know there is not functionality that allows Inventor to search for key words or any words on drawings within notes.  Like I said in my first posting, if Vault is involved there are more search functions in that as long as properties are used with values.
Best Regards,
Scott McFadden
Active Contributor
Message 7 of 13 (332 Views)
07-25-2013 12:52 PM in reply to: Cadmanto
What is vault? Isn't Inventor supposed to be the latest and greatest AutoCad version. Thanks for trying to help me out!
*Expert Elite*
Cadmanto
Message 8 of 13 (328 Views)
07-25-2013 12:59 PM in reply to: immunoman
This link should help describe what Vault is.
http://www.autodesk.com/products/autodesk-vault-family/compare
Inventor is completely seperate from Autocad.  While they are both owned by Autodesk one is 2D and the other is 3D.  Yes, there is Autocad 3D, but that is a very watered down version of what Inventor brings.
Hope this helps.
Best Regards,
Scott McFadden
*Expert Elite*
Curtis_Waguespack
Message 9 of 13 (324 Views)
07-25-2013 01:04 PM in reply to: immunoman
Hi immunoman,
This functionality is missing, but you can go here and add a kudo to show your support for this idea:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Find-and-Replace-text-search-in-Inventor-files/id...
As a work around, what I do for drawings is export the drawing as a PDF file and then use the Find tool in Acrobat Reader to locate the text. I don't run into this need very often, since so much of the information in Inventor files can be linked to some source property or symbol definition where it can be changed, but it would be a nice tool to have from time to time.
Keep in mind that if you're
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
Curtis_Waguespack
Message 10 of 13 (322 Views)
07-25-2013 01:07 PM in reply to: immunoman
Hi immunoman,
Autodesk Inventor is a completely separate program than AutoCAD. The two are both CAD applications, and are both owned by Autodesk, but as far as I know, they are maintained and developed by different programming teams.
I hope this helps.
Curtis
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
