Inventor Forum
How do I create an iproperty with a pull down menu?
3 REPLIES 3
1443 Views, 3 Replies
I want to create an iproperty that has a pull down menu where I can make a selection. Can this be done? Can I import this data from a txt, csv, xml file?
3 REPLIES 3
pcrawley
Quick answer is "yes" to all the above.
For the iProperty question, you can do all this with things like multi-value parameters (and maybe a little bit of iLogic).
For the import data, depending on what you are trying to do, you can do all of what you ask quite easily.
If you are looking for a more specific answer, perhaps you can refine your question a bit - give a specific example of what you are trying to do (and why) and someone may be able to elaborate on what I've said already.
Peter
jletcher
I did not make it with a external file but if you need it that way let me know I can change it to an excel file. Longer code but can be done that way.
 This way I just used ilogic and parameters. This drop down controls the description in iProperties.
 Part is attached for you to look at.
jletcher
in reply to: jletcher
Oh to get to the list you can do it through the parameters.
But in this I made a form in the ilogic browser just click on form  Drop Down List and it will pop up.
