I want to create an iproperty that has a pull down menu where I can make a selection. Can this be done? Can I import this data from a txt, csv, xml file?
I did not make it with a external file but if you need it that way let me know I can change it to an excel file. Longer code but can be done that way.
This way I just used ilogic and parameters. This drop down controls the description in iProperties.
Part is attached for you to look at.
Oh to get to the list you can do it through the parameters.
But in this I made a form in the ilogic browser just click on form Drop Down List and it will pop up.
