Inventor General
Member
GillisPatrick
Message 1 of 8 (959 Views)
How do I animate my Geneva Cam using Inventor Studio?
959 Views, 7 Replies
05-31-2012 10:42 AM
I used the Active Constraint opition to make the parts interact but I cant figure out how to animate it. I know it is possible, I just have no idea how to. Could any one possibly tell me or give me a link showing how to??
Distinguished Contributor
hfds006
Message 2 of 8 (915 Views)
Re: How do I animate my Geneva Cam using Inventor Studio?
06-06-2012 09:31 AM in reply to: GillisPatrick
Have you had any luck sorting this out?
I'd love to see the end result.
JDMather
Message 3 of 8 (901 Views)
06-06-2012 10:36 AM in reply to: GillisPatrick
I think you will need to set that up in Dynamic Simulation and then Publish to Studio.
That one is particularly easy - can you attach your assembly here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
GillisPatrick
Message 4 of 8 (881 Views)
06-09-2012 09:37 PM in reply to: JDMather
Here is all the part files including the assembly. And whats is Dyanamic simulation? I was trying to use Inventor Studio but is Dynamic simulation easier?        http://dl.dropbox.com/u/39599771/Geneva%20Drive.rar
JDMather
Message 5 of 8 (872 Views)
06-10-2012 04:48 AM in reply to: GillisPatrick
I am not interested in going to a third party site to see your files.
Attach here as suggested.
Dynamic Simulation is part of Inventor Professional (students can download Inventor Professional for free from http://www/autodesk.com/edcommunity).
If you can attach your files here I can show you how simple this problem is. (and don't use *.rar either)
Member
GillisPatrick
Message 6 of 8 (864 Views)
06-10-2012 07:57 AM in reply to: JDMather
Ok, sorry. I didnt know I could just attach it here. And theres one more part to the assembly I'll attach in the next post.
Member
GillisPatrick
Message 7 of 8 (863 Views)
06-10-2012 07:58 AM in reply to: JDMather
JDMather
Message 8 of 8 (855 Views)
06-10-2012 09:49 AM in reply to: GillisPatrick
First thing I notice is that some of your sketches are not constrained.
Second thing I noticed is that the drive pin on the Input gear is Ø14 and the slot on the Geneva is also 14mm.
This won't work in the real world.
Some pins will be slightly larger and some slightly smaller depending on the manufacturing tolerance.
Sole slots will be slightly smaller depending on the manufacturing process.
Even if the manufacturing process was exact - there would still need to be clearance between the parts.
Since all of the sketches were not dimensioned - I did not bother to check other for other conflicts.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
