Hi there,
I have an assembly which is in essence a 5m long welded I-beam (400m x 130mm), it has certain features which mean i cant just use a standard beam.
This beam is expected to shrink length ways as its welded.
What i need to be able to do is to show certain dimensions at certain points of the build, i will try and explain this
Restrictions i have
Can anyone help with a simple workflow for this
Regards
Lee Gardner
Inventor Pro 2014
Dell T7600
Create the IAM weldment and then Derive the "shrunk" ibeam into a IPT and use the SDK tools with scaling in the length direction to reduce the lengthto the 5mm less.
Hi Blair,
Thanks for that, i will give that a crack but i was hoping something was available maybe at part level, similar to configurations in solidworks.
Regards
Lee Gardner
@Anonymous wrote:
Hi Blair,
Regards
Lee Gardner
Yep ... iParts.
Too bad you can't use them. 😛
Rusty
Hi guys,
Thanks for the advice,
I think the solution for us will be to derive the part and use ilogic and parameters to adjust the size
Not the best solution but the simplest for our system to handle
Regards
Lee Gardner
