Inventor General
Active Member
urmil2229
Message 1 of 3 (1,131 Views)
Accepted Solution
How can UCS Change
1131 Views, 2 Replies
05-02-2012 11:02 PM
Dear Sir,
As per file attached named UCS-01, there is by default UCS comes in part & assembly files.
I want the by default position of UCS, as I have attached file named UCS-02.
Pls suggest the settings.
Urmil Bhavsar
*Pro
sbixler
Message 2 of 3 (1,069 Views)
Re: How can UCS Change
05-06-2012 11:44 AM in reply to: urmil2229
In your part and assembly templates, orient the coordinate system as you have shown, then right click on the View Cube and select Set Current View as Home > Fit to View.
Active Member
urmil2229
Message 3 of 3 (1,053 Views)
05-06-2012 09:51 PM in reply to: urmil2229
Dear sir,
We got success as per your suggestion.
Thanks a lot . . .
urmil bhavsar
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
