Inventor Forum
How can I measure distance between centers of balls?
3 REPLIES 3
WHolzwarth
616 Views, 3 Replies
I'm just playing with a rotor head of a model helicopter (see picture). For proper initial alignment, all main parts shall be setup parallel against one-another. This can be done by aligning the length of the ball linkages.
Smiley SadBut therefore I need to know the distance of the ball centers. How can I do that? (STEP file for testing with different Inventor versions is attached).
Thanks for hints
Walter
Walter Holzwarth
3 REPLIES 3
JDMather
in reply to: WHolzwarth
What if you put Workpoints at the centers of the spheres?
WHolzwarth
in reply to: JDMather
Hmm, Jeffrey. I'm having difficulties with this task, because I get no response of my selection.
Can you show your file?
Walter
Walter Holzwarth
WHolzwarth
Next morning:
- Tried it in an assy with two single parts: Center points could be found
- Tried it in actual assy with many parts: No center points selectable
I've been using adaptivity instead. For constraining, center points are selectable. But not for measuring.
Hoping for the next release
Walter
Walter Holzwarth
