Inventor Forum
How can I draw this goove
9 REPLIES 9
Message 1 of 10
097013309
1336 Views, 9 Replies
Anybody can show me how to draw this groove from blueprint please.
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: 097013309
Looks like a Revolve - Cut to me.
You attached an iam (assembly file).
That drawing looks like it should be an ipt (part file).
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Message 3 of 10
097013309
in reply to: JDMather
In the process I probably open it in the assembly and save it as assembly file ( *.iam) and lost my part file ( *.ipt) can this  be revers?
Can you elaborate about in little more then (Revolve-Cut) so I can draw it please.
Message 4 of 10
Pauli666
You dont say what version you are running, here is revolve & extrude example (Can be accomplished in more ways i am sure) using IV2013
Message 5 of 10
JDMather
You cannot save a part file as an assembly file.
Your part file name is Hinge_Mount.MCNEIL.IPT search your hard drive.
I recommed that you first learn how to set up a project file (*.ipj)
I recommend that you put this aside for a while and go through these
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Message 6 of 10
097013309
in reply to: Pauli666
I am running Autodesk Inventor Professional 2014 Student version.
I can't open your file. When I click on attachment Inventor opening it ,but nothing on the screen or browser.
Thank you for answer.
Message 7 of 10
097013309
Ok. I find my file  and I am attachung itI stiil need advice how to do this groove. Do I should make costruction plane firs? I need surface to put drawing on it ? How I can "go Inside hole" to be able to draw it?
Message 8 of 10
097013309
I find file on the stick. I am attaching it but still need some help. Just tell me seps please.
Message 9 of 10
conklinjm
Unfortunately I have an older version of Inventor and cannot open your part; however, I shall try and answer your question.
Yes, depending on how you created the original sketch, you may need to create a construction axis and work plane to create the revolution.
If the original sketch was on the XY plane and the large bore centered at 0,0, you could sketch on the YZ plane.  One method is  ...
1) Create a new sketch on the YZ plane
2) Project the Z-axis
3) Draw beneath it a parallel centerline
4) Dimension between these two lines (i.e. 4.0 in)
5) Sketch the revolution (should take ten lines -- X.XX x 0.125 / 1.130 x 0.056 / X.XX x Y.YY / 0.933 x 0.125 bore)
6) Apply three diameter dimensions using the centerline (i.e. X.XX, 1.130 & 0.933)
7) Apply collinear constraint between the two X.XX line segments
😎 Apply three length dimensions (i.e. 0.125, 0.056 & 0.125)
9) Project either the top / bottom edge of the raw material or the two ends of the larger circular bore
10) Constrain the two ends of the revolution to either the end points of the projected edge (line to point) or the two circular projections (collinear lines);  Note that the length Y.YY is not needed to be dimensioned as the bore will automatically adjust to the width of the raw material due to these projected elements & constraints
11) Finish Sketch
12) Revolve using the cut option
13) Choose a circular Array
14) Pick the Revolution as the 'Feature'
15) Pick the Z-axis as the 'Axis'
16) Set the number to 3, the angle to 60 and the style to dual-direction
HTH
Not sure from where the drawing you are using came but, to completely recreate it, you require more information as many dimensions are missing (such as the size of the bore shown as X.XX above).
Message 10 of 10
JDMather
Open the attached file.
Find the red End of Part marker in the feature browser.
Drag the red EOP marker down feature-by-feature and examine how they were created.
The Revolve feature is one technique.
You should place the origin for the part at the same location as the origin for the ordinate dimensions.
Note that my part sketches are fully defined.
