I installed Autodesk inventor 2012 Premium (design Pack) original, and there are a lot of MDT files came from other factory and I want to use them with Mechanical Desktop 2009. I downloaded MDT 2009 from autodesk's site, but I couldn't ACTIVATE the program. How can activate MDT 2009 or can I activate MDT 2009, legally......
and can JDMather reply me... I can't sent him private message.....
Thanks for all...
Solved by sam_m. Go to Solution.
I don't think you should need to activate - it should run under your Inventor license AFAIK.
I wait for a month,
if it continiue to work, ther is no Problem..
Thanks...
Don't wait.
Are you getting 30-day Trial/Activate splash screen when starting MDT?
If you go to Help>.....Mechanical Desktop>Product Information - what does it say the License Expiration Date is?
I tried to enter inventor 2012's key but MDT 2009 wants request code, I think I made a mistake; key is correct but Imustn't
enter by hand. Now I can't enter a key or it doesnt ask for internet activation, I use like that.....
I'm getting 30-day Trial/Activate splash screen when starting MDT.
Activate Product
Run Product
top of them
23 days remained
thanks for your efforts,
MDT is 2009, so needs to be activated with the Inventor 2009 suite serial, which is different from your 2012 serial.
You have to goto your subscription website and request an old version serial for the 2009 suite - use this serial to unlock MDT.
yes, it's a real mess... and yes, when they stop allowing us to get 2009 serial numbers (next year?) everything will go v v bad. Why they can't incorporate the MDT translator into Inventor to prevent the need to install MDT at all is beyond me (and something that should have been done a LONG time ago).
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
I'll try,
thanks for all, Sam
you might have better luck over in the "Installation and Licensing" forum;
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
@iErdogan wrote:
I can't do activation, I enter inventor 2012 key(design suite premium pack) for MDT 2009, it wants request code, Ienter request code, it says" your request code is wrong" (subscribe, registry in Autodesk website) All right, its 2012's key not MDT 2009's key. So I Can't do activation. How I will solve I don't know! 😞
As I posted before, the Inventor 2012 code will not work, you NEED an Inventor 2009 code. I had a similar problem when I was trying to use a 2011 code to activate it, I emailed Autodesk and this was the reply:
"Please note that you are required to submit your previous version serial number request online via Subscription Center. As the installed version is 2009, we would need to issue a serial number for this version first. Once you have received the serial number, please try again and if the online activation would fail we can manually generate the activation code. Please follow the below information in order to submit your previous version request.
In order to activate the requested product version, please login to Subscription Center to request a serial number of the version that you require.
Please note that only Contract Manager and Software Coordinator are able to apply for the Previous Version Serial Number.
- Login to Subscription Center
- Click Subscription Administration
- Click Request Previous Version
- Select Deployment
- Complete Previous Version Request Form and submit it
Thank you for contacting Autodesk."
So, goto http://subscription.autodesk.com/ and request a previous version of Inventor (asking for 2009) to get a 2009 serial, which you then use to unlock MDT 2009...
Sam M.
ok, I have no subscription, and so I couldn't activate. I need to to have subscription for previous version activation.
Thanks for all of you!
