Inventor General
Active Contributor
JohnnyKash
Message 1 of 13 (603 Views)
How Complex of an Assembly Can Inventor Handle?
603 Views, 12 Replies
11-07-2012 08:42 PM
I'm wanting to model something rather unusual. It's simple and complex at the same time. I've already got the most important part to make it modeled, and I can toss the others off quickly (they're just sticks at different scales), so it will be easy--I can handle tedious work if it's making something I enjoy.
But I don't want to waste a whole day putting it together if the program can't handle it. Can Inventor handle something like this? http://www.frc.ri.cmu.edu/users/hpm/project.archive/robot.papers/1999/NASA.report.99/9901.NASA.S5.ht...
I'd only make it to six levels of branching, so 243 end fingers. It'll look much like the 5th image up from the bottom of the page, but I'll be putting the fingers on a joint that is rather more complex than a ball-and-socket: 11 moving parts.
So in total it will have . . . 2,673 + 243 + 891 + 81 + 297 + 27 + 99 + 9 + 33 + 3 + 11 + 1 = 4,368 movable parts.
*Expert Elite*
JDMather
Message 2 of 13 (582 Views)
Re: How Complex of an Assembly Can Inventor Handle?
11-08-2012 12:51 AM in reply to: JohnnyKash
JohnnyKash wrote:
So in total it will have 4,368 movable parts.
What is your purpose for having the parts movable?
If this is simply artistic sculpture you want you can simplify by grounding the parts.
I see no discussion of motion control.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
JohnnyKash
Message 3 of 13 (530 Views)
11-08-2012 01:56 PM in reply to: JDMather
I want to be able to reposition the fingers to make them look like they're grasping objects, or just put them into interesting poses.
I am going to ground the trunk-stem. These fractal hands are going to be placed on the ends of articulated arms in another assembly, which are in turn going to be attached to a robot body.
No motion control. I've just been selecting the smaller assemblies inside the larger assemblies and repositioning them one at a time. Since they're constrained, everything up the chain from the repositioned assembly follows to where they should.
Active Contributor
JohnnyKash
Message 4 of 13 (455 Views)
11-21-2012 12:49 PM in reply to: JDMather
I'm stuck right now. I've had all the different scales of components modeled for at least a week, but when I start putting them together and testing it, there is a major problem. For some reason, when two or three parent-assembly files that have different names, but are otherwise clones of each other, are placed together in a larger assembly file, the daugher-assemblies mirror one another's movents even though they're in completely different parent-assemblies.
Why is this happening, and is there anyway I can fix it? I need these assemblies-in-assemblies-in-assemblies . . .  to be like matryoshka-dolls: a change at one scale in one doll won't affect other dolls of the same scale that are inside different parents.
*Expert Elite*
JDMather
Message 5 of 13 (434 Views)
11-21-2012 03:56 PM in reply to: JohnnyKash
Depends on how you created them (don't use Windows Exporer to copy/rename).
Also - they will need to be set to Flexible in the main assembly (but it sounds like you already did that).
*Expert Elite*
blair
Message 6 of 13 (421 Views)
11-21-2012 07:43 PM in reply to: JDMather
You don't list any system hardware spec's, a decent spec'd machine should be able to handle it. I wouldn't want to try it on a Core 2 duo machine with 2Gb of memory and an integrated graphics card.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Contributor
JohnnyKash
Message 7 of 13 (409 Views)
11-21-2012 11:17 PM in reply to: JDMather
I copy/renamed them in Inventor from the get-go.
Just to make sure there's no misunderstanding: the daugher-assemblies do share the same name between parents. Inside the smallest scale parent-assembly (1/16th), there are three daughter-assemblies: 1, 2, and 3. Their actual names are much longer and more descriptive than that, but the numbers on the ends tell them apart.
1, 2, and 3 packaged inside Parent A shouldn't, if everything was working right, affect changes to 1, 2, and 3 inside Parent B when A and B are both in a larger assembly, correct?
Active Contributor
JohnnyKash
Message 8 of 13 (407 Views)
11-21-2012 11:27 PM in reply to: blair
4GB RAM, 2.1 GHz processor.
This hiccup is happening when I'm mating the 1/16th scale assemblies to the 1/8th scale assemblies. There's not that many parts at this level. It's not having difficulty processing the changes when I move parts; I don't think it could be that.
Active Contributor
JohnnyKash
Message 9 of 13 (333 Views)
11-26-2012 11:09 AM in reply to: JohnnyKash
I've tried so many different things into the early mornings on several days, and nothing works. Is there no way to get it to recognize the nesting of the assemblies, and not cause changes between them? Building the bush out of individual elements would be nuts, like building a tree one twig at a time. I need to be able to clone assemblies, nested in assemblies, nested in assemblies, over and over, so I don't have to constrain almost 700 sub-assemblies (half of which are assemblies in their own right).
What can I do? Can the program even do this?
*Expert Elite*
JDMather
Message 10 of 13 (319 Views)
11-26-2012 12:08 PM in reply to: JohnnyKash
Most likely the only way to get a definitive answer is to have an experienced person take a look at the assembly.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
