I have fixed most of my hole problems. I had the countersink radius to
large, so that it broke through the wall of the tube, before it had tappered
down to the correct radius. Fixing this resolved most of my issues. I can
now add hole notes and center marks to the hole, most of the time 😉
The imported diemensions and broken views is still an issue though.
Can't wait to get hold of SP1.
Stephen.
"Neil Munro" wrote
> See embedded: (note: pre-release of SP1 for R6 installed, don't know if R6
> will show the same results)
> > My first problem is I can not create hole notes for the holes, moving
the
> > mouse of the hole high lights it but it does not let me select it. (The
> > hole is in the same plane as the drawing)
> Click on the hole a number of times. It took 3 or 4 clicks to get the
hole
> note to appear. This works even on the holes that are not aligned to the
> view.
> > My second problem is trying to place a general dimension to show the
> > location of the hole with regards to the end of the tube, it will not
> allow
> > me to select the center of the hole.
> Worked fine here. Try placing a center mark on the hole, and dimension to
> it. (Standard procedure anyway?)
> > My third problem is if I do 'Get model Dimensions' then it imports the
> > dimension I was trying to draw above, now if I break the view the
> dimension
> > does not update with the break so that the dimension stays the same size
> on
> > screen, i.e well of the side of the page)
> Broken views had a number of issues in the initial R6 release. I'm seeing
> much improvement.
> > My 4th problem is that puting the break in the drawing consumes 100% CPU
> for
> > about 20seconds. This is a single extrusion I am trying to break!!
> > Is anyone else having this sort of problem, I am hoping that SP1 is
going
> to
> > fix this!
> > Seeing as the project I am just starting on is made entirly of round
> parts,
> > Inventor isn't looking like it is going to be much use to me!
> > Stephen.
