Is there a way to toggle visibility of the originator for a hole table in the plot ? It would be good to be able to remove this from the plot of the drawing, thanks
Solved by mpatchus. Go to Solution.
Right click on the origin indicator and select "Hide Origin Indicator".
Thanks great thanks, how would I turn this back on if I need it back ?
Right click on the hole table itself and select the Visibility tab.
You can control the Origin visibility on/off from there.
Many thanks, this anwers my query.
