I moved the hole table from the original sheet to an other, but the fields in the title block of the new sheet don't update with the iproperties of the model
Solved by Nicolas.Bourquin. Go to Solution.
Dear Karol-or,
If the fields in your titleblock are coming from the model iproperties, this is a normal behaviour of Inventor.
The holes tables (or also for example part lists) are only considered as "annotations" by Inventor.
In the extra sheet containing only the Holes table, the easiest solution could be to add a base view of the 3D model outside of the drawing field to get the information from the 3D model also in the title block of this sheet.
I hope that will help you.
Please, mark any response clicking on "Accept as Solution" button if it answers your question
