Inventor General
Member
VitaliHoerbiger
Message 1 of 6 (268 Views)
Hole table not updated the hole sizes.
268 Views, 5 Replies
11-29-2012 05:41 AM
i have created an idw file of a plate with a hole table in it. i have then changed some of the holes to different sizes.
when i went to the hole table it had not  updated the hole sizes.
------------------------Few Hours later.
If I click on the section view with the hole table Letters, and click update it will update the holes sizes.
It must be correct view.
Is there a way to do it automatically? (During load/save/close/creating PDF)
Employee
jozef.dubaj
Message 2 of 6 (241 Views)
Re: Hole table not updated the hole sizes.
12-03-2012 02:42 AM in reply to: VitaliHoerbiger
Hello Vitali,
could you attach the ipt and idw file (complete dataset). Normally it should update automatically.
Jozef
Member
VitaliHoerbiger
Message 3 of 6 (227 Views)
12-03-2012 08:33 AM in reply to: jozef.dubaj
Hello Jozef,
I can't attache IDW to this post, I used reply and will send you e-mail with these two files.
I am using Inventor Professional 2012 64-bit Edition SP2  with all latest updates.
Employee
jozef.dubaj
Message 4 of 6 (212 Views)
12-04-2012 01:38 AM in reply to: VitaliHoerbiger
I've looked at the dataset you sent me. Seems that ipt file does not identify itself as updated so the idw won't automatically update. However if I change the diameter of the hole it updates automatically. I have tried several workflows trying to get idw not updating but no luck.
I'd like you to try to describe exact steps what edits and how you did in the ipt. Best would be also to send me the ipt saved prior edits.
-Jozef
Member
VitaliHoerbiger
Message 5 of 6 (184 Views)
12-05-2012 06:24 AM in reply to: jozef.dubaj
Jozef,
Thank for looking at this problem.
Changing the diameter of the hole, and updating the drawing is not a problem. View and Dimention on the view updating with out prolem.
Problem with hole table "Description" column is showing old information, and it will show it until I manually update the view with the holes letters.
See images
Employee
jozef.dubaj
Message 6 of 6 (168 Views)
12-06-2012 01:19 AM in reply to: VitaliHoerbiger
You quite misunderstood my last post. I see the problem described by you. What I did is check wheter it is a permanent problem in the given datased. However i found the IDW updates automatically if any changes are made to the IPT. It means that link between the two works well.
Problem is the state in which you have saved it and sent to me. Seems that you made changes in the IPT by a specific worflow (we need to determine) and Inventor did not set "flag" saying it is out of date for it. As the result the IDW won't update as it "thinks" there are no changes in the IPT.
So I want to find how you get the IPT in that state. Thus I asked for steps (edits description) that has been made. Obviously you changed the diameter of the holes. I need to know how exactly. Just assigned defined user parameter? Or changed value of already assigned user parameter. Recreating the hole from scratch? Else? More details the better.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
