Using 2013 sp1.1
After I change the hole size in the part, the callout in my hole note does not update. (crazy, I know).
If I pull a new hole note after the change, it has the correct dimension. But, if I change the hole size again, this new hole note does not update.
I put the part on a new idw and it updates correctly, so somehow the idw is hosed.
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1
Vault Basic 2013
Kirk,
Couple of thoughts.
Did you try a complete rebuild of the drawing after the update?
Also what happenes if you use that same part and create a completely new drawing? Does that drawing update?
"Same part in new drawing"... it updates correctly (see my original post).
"Complete rebuild of the drawing".... Its greyed out in the idw. A rebuild all of the ipt after the change doesnt help either.
Sorry to bring up an old message...but did you find an answer to this? I am using Inventor 2014 (all service packs installed) and I just had the same issue as the video you placed. Edited a hole in the part, but the .hole note did not update. Just wondering if I am missing something.
Thanks for any help
Mark
Hi Mark,
can you please send me the dataset (IPT and IDW) which exhibits this problem? That would help me a lot to see where the problem is.
Ladislav
ladislav(dot)pcola@autodesk(dot)com
