Hello all,
My problem is the hole chart feature in a .idw drawing will not work for an assembly file in .iam format (see Capture1.JPG). I have tried the "Hole Selection" "Hole View" and "Hole Features" options to no avail. I can get the hole chart to work perfectly for a part file in .ipt format but when I apply the same methodology to an assembly file it does not reconize any of the holes.
I have attached both the assembly and drawing files and yes, the holes were created with the hole feature and not with extrusion.
Any advice is much appreciated.
OS: Windows 8.1 x64
Program: Inventor 2014
Solved by rdyson. Go to Solution.
Solved by blair. Go to Solution.
So basically the only way to get the hole chart to detect the holes on the .iam file would be to add all the holes in the .iam file over top of the existing holes from the .ipt?
You should be able to get a hole chart in an assembly drawing, even if the holes are created in the parts. I just tried it with Inventor 2014 and it works for me.
Only thing I can think of is that the view is not perfectly aligned with the face of the part(s), which it must be in order to make any sense of X-Y coordinates.
Sam B
Inventor 2012 Certified Professional
Inventor Professional 2014 SP2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Thats how I assumed it should be able to work...however I am aligning the view the exact same way using the part and assembly file and only the holes are only detected on the part file no matter how many times I try to re-align.
Only thing I can suggest is to post the dataset and see if anyone can figure it out.
Sam B
In my previous posts I have posted the .iam along with the three .ipt files that make up the assembly as well as my .dwg. What other files should I post?
Sorry, you did indeed post the files. And they show that the assembly is off by the angle that rdyson shows in his post. If you place the view looking directly at that face, you will be able to place a hole chart.
Sam B
That was the issue, thank you both very much. I am sure I placed the sheet metal plate at the grounded origin but perhaps I accidentially clicked and moved it as I was aligning the inserts.
What is that oragne plane you have in the picture? A work plane? The only way I could tell the plate was missaligned was looking perpendicular to the top edge through the holes and seeing they were slightly off of each other.
To correct the problem, or at any time after placement, you can use the Ground and Root Component tool. This is in the Productivity panel. This not only grounds the selected part, it also places flush constraints to the origin planes, so it cannot be accidentally moved.
Sam B
Thanks for the tip, I do have one more question. I am unable to select the external radius of the inserts that face upwards. D7 in the picture below refers to the diameter of the hole where the fastener is to be placed, when what I would like it to refer to is the diameter of the hole in the sheet metal where the insert needs to be placed.
