I am new to inventor however have used other software in the past, I am trying to learn how to carry out stress analysis within inventor and have applied what seemed logical to me, however when I got my results file it does not seem to add up.
I want to investigate the effect that a crack will have on a piece of steel plate, I have applied a fixed constraint to one side of the plate, and a load to the other side, as well as a seperation contact on the sides of the crack (see file attached)
Can anyone advise if this is correct?
@Anonymous wrote:....however when I got my results file it does not seem to add up.
Please explain. How do the results differ from what you expected?
I thought the results looked low, (all 0.xxx values) however I think what I was doing before was wrong so discarded them. It was also showing the red (which I guess is highest stress point) to be away from the weak point built into my model (the fracture called extrusion 2)
I have started the Stress analysis again, this time I have 'fixed constrained' one end of the plate, and spil the top face to apply a load to the other end, I have applied a material and also generated a mesh. Is it possible for you to check it out and let me know if I am on the right track?
Also can you recomend any guides that go through this kind of thing from a beginner level, I understand modeling (very similar to UG which I work on) but I am totally new to FEA.
Before we go too far - are you really after Fracture Analysis?
In that case you probably want to use another product (like maybe Autodesk Analysis) as Autodesk Inventor is only useful in the Elastic range of deformation.
Second - I would have called that feature a V-notch rather than a "crack".
It also concerns me that your load is completely different direction than original file you posted.
Are you sure of what you are after.
If you are a student - there are some tutorials here http://www.autodesk.com/edcommunity
You might also check www.amazon.com for book by Wasim Younis.
Yea I am a student hence the mixed up forces applied. I am aware the Inventor can't work out fracture analysis, will have a bit research on the other software package you suggested as it may be more suitable for me.
I aimed to load the part with axial force, and realise that is not what was shown in the second example! I was just trying different approaches to see if the results made more sense to me.
I expect to see in FEA, evidence that the 'crack' would grow and propogate under load. However that is not what I have seen so far, the stress/strain has been distributed evenly accross the part.
I will have a look at the guides on the link you posted and see if I can get any further - Thanks for you help!
