Inventor General
pball
Message 1 of 9 (411 Views)
Help with sheet metal part
411 Views, 8 Replies
10-25-2013 07:49 AM
I could use some help making a sheet metal part work. The part is good except for where two flanges meet and don't have a gap, which makes it impossible to get a flat pattern.
The part attached is from 2014 and I have two pictues the part also.
*Expert Elite*
mcgyvr
Message 2 of 9 (387 Views)
Re: Help with sheet metal part
10-25-2013 09:30 AM in reply to: pball
How will this part be fabricated? press brake only?
Why not just sketch the complete bottom face then add the flanges
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
pball
Message 3 of 9 (382 Views)
10-25-2013 09:33 AM in reply to: mcgyvr
Press brake only
Valued Contributor
jneal
Message 4 of 9 (332 Views)
10-25-2013 03:16 PM in reply to: pball
See attached. This is how i would do that piece. I did not bother to trim/fix the ends. I left all of your sketches in tact as well...
Application Engineer
All CAD Northwest
Meridian ID
Active Contributor
KulasekaranK
Message 5 of 9 (268 Views)
10-28-2013 04:36 AM in reply to: pball
Hi,.
I am using inventor 2012 so i could not use your file,.
From the attached picture I understud that, the part doesn't have a slit to 'unfold' (as you told)
pball wrote:
" where two flanges meet and don't have a gap,"
Make a slit before creating a flange at the meeting point,.
pball
Message 6 of 9 (266 Views)
10-28-2013 04:38 AM in reply to: jneal
Well I was looking for a way to have it with the ends like they are in my original part. I ended up after starting this thread using a method like you posted and manually fixing the ends because I needed to get the part done.
KulasekaranK
I don't quite understand what you mean, could you make an example or something?
icouture
Message 7 of 9 (229 Views)
10-28-2013 08:11 AM in reply to: pball
The easiest way to do this would be to make the bottom of the piece as a face. Once that is done, use the flange tool to make your flanges. Once the part is fabricated you'd then only need to get a welder to seal off the slits.
pball
Message 8 of 9 (217 Views)
10-28-2013 09:27 AM in reply to: icouture
That's how jneal did the part he attached and how I ended up making my part. I'm trying to see if there is a method to making this part where the ends of the flanges do not need to be fixed.
Valued Mentor
IgorMir
Message 9 of 9 (124 Views)
10-28-2013 05:43 PM in reply to: pball
Please have a look at this part. I think it answers your question about the ends of the returned flanges.
The file is in IV2010 format.
Best Regards,
Igor.
Web: www.meqc.com.au
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
