Inventor Forum
Help on offseting flange using Sheet Metal
2 REPLIES 2
bachxuanguyen
344 Views, 2 Replies
I'm trying to make this part on Sheet Metal, and I have to offset this flange at 28 degree that meet 0.37". The thickness is 0.12". Currently, the only method that I know how to meet that 0.37" is by playing around (guess and check) with the number in picture 3. Do you guy know any other methods to create this offset part.
Bach
Inventor 2011
Window 7, 64bits
2 REPLIES 2
Hi bachxuanguyen,
Can you use the Contour Flange tool as is used the attached example parts?
I hope this helps.
Curtis
Thank you, Curtis. That is what I look for, I will try that methods now, thanks again.
Bach
Inventor 2011
Window 7, 64bits
