Inventor General
Active Member
Message 1 of 3 (177 Views)
Help on offseting flange using Sheet Metal
177 Views, 2 Replies
05-10-2012 02:12 PM
I'm trying to make this part on Sheet Metal, and I have to offset this flange at 28 degree that meet 0.37". The thickness is 0.12". Currently, the only method that I know how to meet that 0.37" is by playing around (guess and check) with the number in picture 3. Do you guy know any other methods to create this offset part.
Bach
Inventor 2011
Window 7, 64bits
Curtis_Waguespack
Message 2 of 3 (170 Views)
Re: Help on offseting flange using Sheet Metal
05-10-2012 02:22 PM in reply to: bachxuanguyen
Hi bachxuanguyen,
Can you use the Contour Flange tool as is used the attached example parts?
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Member
Message 3 of 3 (103 Views)
05-11-2012 05:54 AM in reply to: bachxuanguyen
Thank you, Curtis. That is what I look for, I will try that methods now, thanks again.
Bach
Inventor 2011
Window 7, 64bits
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
