Inventor Forum
Help me with this Icosahedron!
4 REPLIES 4
NTFA
7726 Views, 4 Replies
I am trying to make a 3d sketch into a solid. After trying everything I can think of, I admit defeat. Can someone tell me how to turn this thing into a solid?
4 REPLIES 4
CCarreiras
in reply to: NTFA
Hi!
A bunch of closed surfaces are solid, simply stich them ...
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
NTFA
in reply to: NTFA
Thanks guys, that worked. I started from that blog, but ran into trouble when it came to the patching. I tried patching before I posted.
The thing is, I was having a really hard time selecting just a single line of the previous patch. I couldn't figure out how to do it. It seemed like if I put the model at an extreme angle I had an easier time singling out the line I wanted.
Did you have a smiliar experience while putting together that post for me?
CCarreiras
in reply to: NTFA
Hi!
Look at "Automatic Edge Chain".
If is on, you can select at a time a serie of continous lines... loops, etc.
If you disable it, you can pick a single line at a time.
CCarreiras
