Inventor General
New Member
Anuvin
Message 1 of 5 (320 Views)
Help me with this Icosahedron!
320 Views, 4 Replies
10-28-2013 02:50 PM
I am trying to make a 3d sketch into a solid. After trying everything I can think of, I admit defeat. Can someone tell me how to turn this thing into a solid?
Distinguished Mentor
ccarreiras
Message 2 of 5 (316 Views)
Re: Help me with this Icosahedron!
10-28-2013 03:01 PM in reply to: Anuvin
Hi!
A bunch of closed surfaces are solid, simply stich them ...
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Curtis_Waguespack
Message 3 of 5 (308 Views)
10-28-2013 03:09 PM in reply to: Anuvin
Hi Anuvin,
These links might help also:
http://www.inventortales.com/2012/10/all-for-fun-creating-20-sided_26.html
http://www.inventortales.com/2012/11/all-for-fun-again-modeling-12-sided-die.html
http://www.inventortales.com/2012/11/for-little-more-fun-10-sided-die.html
http://www.inventortales.com/2012/11/and-yet-again-all-for-fun-8-sided-die.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
New Member
Anuvin
Message 4 of 5 (269 Views)
10-28-2013 05:25 PM in reply to: Anuvin
Thanks guys, that worked. I started from that blog, but ran into trouble when it came to the patching. I tried patching before I posted.
The thing is, I was having a really hard time selecting just a single line of the previous patch. I couldn't figure out how to do it. It seemed like if I put the model at an extreme angle I had an easier time singling out the line I wanted.
Did you have a smiliar experience while putting together that post for me?
ccarreiras
Message 5 of 5 (231 Views)
10-29-2013 02:48 AM in reply to: Anuvin
Hi!
Look at "Automatic Edge Chain".
If is on, you can select at a time a serie of continous lines... loops, etc.
If you disable it, you can pick a single line at a time.
Regards.
CarlosC
Windows 7 64Bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
