Inventor General
Valued Contributor
Message 1 of 4 (300 Views)
Help making sheet metal part
300 Views, 3 Replies
10-12-2012 12:57 PM
I have a 14 gage sheet metal part that follows the profile in the attached picture.  7/8" legs with a 1/16" offset.  Because it's 14 gage, the contour flange won't create it.  I need it to be able to be turned in to a flat pattern so that I may export it to a .dxf.  Is there another way to make this that will allow me to flat pattern it?  I have a couple of pieces like this where the offset is very slim, so I am looking for a way to do all of them like this.
mcgyvr
Message 2 of 4 (280 Views)
Re: Help making sheet metal part
10-12-2012 01:22 PM in reply to: nickv02
That profile is just incorrect. Its not made like that in real life unless its a stamping operation which Inventor cannot properly define the flat pattern for.
How is this part fabricated?
Model the 2 faces then use "bend" to connect them if press braked.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Curtis_Waguespack
Message 3 of 4 (279 Views)
Hi nickv02,
Attached is an example that might give you a hint. I didn't see any information on what version of Inventor you're using, but hopefully you can open an Inventor 2010 file (that's the oldest version I have Installed these days.)
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
Message 4 of 4 (264 Views)
10-12-2012 01:34 PM in reply to: Curtis_Waguespack
Inventor 2013, forgot that.
It's a stamping procedure.  You're right, I was going about it the wrong way and drew it incorrectly.
Curtis, that example is excellent, thank you for your help!
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
