I am trying to find a way to have iLogic code that looks at a part with only one extrusion, such as bar stock or angle stock and automatically export the length to iProperties. As per the request of the other engineers however, this code cannot be based on a common renamed parameter. Also, since no one draws things the same exact way, it can't be based off of a common dimension parameter either. At least not in terms of d0,d1..etc.
Is there such thing as a code similar to variable=standard.extrusionextentslength that I can imbed within an if then that would pull this information from the model?
Solved by Curtis_Waguespack. Go to Solution.
Are these stock items that you are building yourselves, or using the standard items out of Content Center?
If not using Content Center, would it be possible to use CC for what you need? If your engineers are constantly manually remodeling bar stock and angle shapes, there may be time to be saved by changing that process. It would also make it easier to achieve your original request, since the model methods would be consistent.
Hi cereakes,
Below is a real quick adaptation from this thread:
http://forums.autodesk.com/t5/Autodesk-Inventor/Part-Measure-gets-planes/m-p/3843039#M466854
I hope this helps.
Curtis
oDoc = ThisDoc.Document
Dim MyArrayList As New ArrayList
'toggle work plane visibility off
For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
If oWorkPlane.Visible = True Then
oWorkPlane.Visible = False
'add workplane to the array list
MyArrayList.add(oWorkPlane.name)
End If
Next
'toggle work axes visibility off
For Each oWorkAxis In oDoc.ComponentDefinition.WorkAxes
If oWorkAxis.Visible = True Then
oWorkAxis.Visible = False
MyArrayList.add(oWorkAxis.name)
End If
Next
'toggle work points visibility off
For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints
If oWorkPoint.Visible = True Then
oWorkPoint.Visible = False
MyArrayList.add(oWorkPoint.name)
End If
Next
'get measurements
My_x = Measure.ExtentsLength
My_y = Measure.ExtentsWidth
My_z = Measure.ExtentsHeight
'Make longest value the Length, rounded to 2 places
MaxLength = Round(MaxOfMany(My_x, My_y, My_z), 2)
Dim propertyName1 As String = "Length"
'define custom prpoerty collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
'set property value
oProp = oCustomPropertySet.Item(propertyName1)
Catch
' Assume error means not found so create it
oCustomPropertySet.Add("", propertyName1)
End Try
'set custom property value
iProperties.Value("Custom", "Length") = MaxLength
'show max value
MessageBox.Show("The length is: " & MaxLength, "ilogic")
'toggle work plane visibility back on
If MyArrayList.contains(oWorkPlane.Name) = True Then
End If
Next
'toggle work axes visibility back on
If MyArrayList.contains(oWorkAxis.Name) = True Then
End If
Next
'toggle work points visibility back on
If MyArrayList.contains(oWorkPoint.Name) = True Then
End If
Next
I almost posted a very similar rule to Curtis's, because I use something like it every day that I could have easily modified for this situation. I decided against it because it does have a potential flaw depending on exactly what you're building. If this situation doesn't apply to you, his rule should be a good solution.
If the length of the extrusion is ever smaller than the width of the profile, you will get the wrong result from the rule. For example, let's say you're using 5x5 angle, and cutting a 2" long section to make a bracket. The rule will measure in X, Y, and Z directions, then find the longest and set it to the length. In this case, the largest dimension is not the length, but one of the 5" dimensions for the angle legs. Thus, it will say the angle is 5" long, when it should say 2".
